Forums >> Revit Building >> Technical Support >> Invisible construction
Fri, Jul 10, 2020 at 2:27:07 AM | Invisible construction
KarolMolok
Hi comrades,
i have roof with two big dormers. When i make floor plan i can see structure (rafters, etc) only from dormers but not from main roof.
K
Fri, Jul 10, 2020 at 5:06:52 AM | Invisible construction
Not enough information.
Look at what worksets all elements are on.
Look at your view range.
I see different colors for different elements - that means something is different - what?
Fri, Jul 10, 2020 at 6:21:33 AM | Invisible construction
KarolMolok
- no worksets
- i try modify view range, think is ok
- color is just for different dimmensions (color by material), no effect on visibility
- I made structure on two different work planes (roofs). Structure modeled in dormer roof is visible structure in main roof is not.
- when i show hiden elements i can see structure by lines, when i unhide them i cant see them either
Fri, Jul 10, 2020 at 7:25:38 AM | Invisible construction
You say " i try modify view range, think is ok" ... and you say you have 2 different work planes.
Look again at your view range.  Make it deeper and see what happens.
Fri, Jul 10, 2020 at 8:21:00 AM | Invisible construction
KarolMolok
Yes, depth of view is ok, i can see objects below missing elements.
Fri, Jul 10, 2020 at 8:44:25 AM | Invisible construction
Cut a section making sure you show what refernce plains you used in your plan.  Add a line showing the depth of view for your plan. Then pick a dormer rafter shoawing us its properties then do the same for your main roof.
Fri, Jul 10, 2020 at 2:07:21 PM | Invisible construction
hanbyjm
Adjust cut plane?
Mon, Jul 13, 2020 at 6:28:18 AM | Invisible construction
KarolMolok
- like this pictures?
- work planes are different with long names, so it looks same in picture. I set roof surfaces as a work plane.
- i have no filters on, material and family are same, detail level is set to fine
- i try different floors, levels and cut planes. Result is same, structures in main roof is visible only in 3D not in floor plan.
- sorry, soft language is czech
But i am also missing some elements in visible "dormer" part of the roof/work plane. It must be something in beam properities.
I am working on this problem whole week. Thank you for your help.
Mon, Jul 13, 2020 at 8:47:31 AM | Invisible construction
Did you go through all of these?  https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Wed, Jul 15, 2020 at 3:31:43 AM | Invisible construction
KarolMolok
Thank you for your time and help. The link helped me by resigning to find the error. It was in beam elements setting and i couldnt find it. I replace all elements in timber framing with another and it helped.
Once again thanks.
Invisible lines removed from Line Styels
Mon, Feb 21, 2011 at 12:10:18 PM
Invisible Dimension Lines
Thu, Dec 29, 2011 at 6:04:48 PM
how to create video in stages of construction
Sat, Mar 21, 2015 at 12:27:46 PM
Rendering an invisible wall.
Sun, Apr 24, 2011 at 12:01:49 PM
Making The Invisible Visible
Thu, Aug 19, 2010 at 4:10:34 AM
Page generation time: 0.1198
