Forums >> Revit Building >> Technical Support >> align Revit's asphalt shingle roofing in plan view to sloping side
Sun, Jun 28, 2020 at 2:12:30 AM | align Revit's asphalt shingle roofing in plan view to sloping side
elizabethpetermathew
Hello,
I am using Revit's Asphalt shingle roofing as my roof finish. But in my roof plan it is all aligned in the horizontal direction, not parallel to the sloping surface. It should be horizontal or vertical depending on the sloping surface. How do I get the pattern to align with the roof slope surface correctly? See attached. Thank you in advance.
Sun, Jun 28, 2020 at 7:16:03 AM | align Revit's asphalt shingle roofing in plan view to sloping side
Is that a model pattern assigned to the material?
To rotate a model pattern in a view, you need a view that is parallel to it.
Edited on: Sun, Jun 28, 2020 at 7:24:03 AM
Sun, Jun 28, 2020 at 8:35:09 AM | align Revit's asphalt shingle roofing in plan view to sloping side
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
You're using drafting pattern. Use this one instead. Adjust scaling to about 80 or so.
*Shingle,  Roof shingles
;%TYPE=MODEL
0,             0,             0,             0.187,         0.085,         1.275,         -0.17,         0.425,         -0.085
0,             0.11305,       0.0425,        -0.085,        0.11305,       0.255,         -0.02805,      0.51,          -0.06375
0,             0.0425,        0.07225,       0.442,         0.05695,       0.68,          -0.119,        0.34,          -0.085
Wed, Aug 12, 2020 at 4:47:28 PM | align Revit's asphalt shingle roofing in plan view to sloping side
Thank you.
sloping roofing
Wed, Mar 9, 2005 at 1:21:52 PM
Realistic View vs. Rendered View
Wed, Nov 5, 2014 at 7:41:26 AM
Can't see my columns in plan veiw! Revit 2009
Mon, May 25, 2009 at 2:27:19 AM
surface pattern in "this view only"
Sat, Feb 20, 2016 at 7:34:11 AM
Revit Roofing
Tue, Mar 23, 2010 at 2:30:31 PM
Page generation time: 2.0145
