31 Users Online (29 Members):
Forums >> Revit Building >> Technical Support >> printing problems in Revit 2013, windows 10
Hi,
Does anyone have tech support advice about printing to pdf problems in revity 2013 for windows 10? Basically the print window opens but none of the buttons work to set print setup.
any help would be appreciated.
----------------------------------- VND |
Look at your pdf program that you use - that is probably your problem.
If this is a new problem, then maybe that just needs to be re-loaded.
Look at a different pDF program.
thanks, got it sorted shortly after it began to work again.
Revit Print Problems - UPDATE |
Fri, Sep 2, 2016 at 1:44:13 PM
Printing |
Thu, Jun 14, 2018 at 12:59:04 AM
Revit Structure 2013 windows 7 & windows XP Compatibility |
Wed, May 15, 2013 at 1:27:10 PM
Graphic problems while in 3D Realistic view in 2013 |
Tue, Sep 25, 2012 at 4:10:41 PM
Revit 2013 and Windows 8 |
Thu, Dec 12, 2013 at 12:27:01 PM
