Forums >> Revit Building >> Technical Support >> Roof slope different on roof plan and exterior elevation
Thu, May 28, 2020 at 1:32:32 PM | Roof slope different on roof plan and exterior elevation
elizabethpetermathew
Hello,
Why does my roof slope on the roof plan show correctly as 4"/1'-0"and in the exterior elevation it shows 3"/1'-0"? I use the same symbol.   Any advise on how to fix this or if I am doing something wrong? The roof plan is correct slope.
Thank you in advance.
Thu, May 28, 2020 at 2:46:46 PM | Roof slope different on roof plan and exterior elevation
It sounds like you have a hipped roof and in elevation, you are picking the hip line, not the actual roof.
Thu, May 28, 2020 at 5:22:40 PM | Roof slope different on roof plan and exterior elevation
Hmmm makes sense, thank you for the response. I scrolled through till it showed the correct roof slope. Thank you.
Roof slope not showing up correct
Thu, Jul 11, 2013 at 10:37:30 AM
Roof plan
Fri, Sep 2, 2016 at 4:58:14 PM
Roof slope line incorrect
Wed, Sep 30, 2009 at 6:28:37 AM
Show roof slope?
Fri, Jul 23, 2010 at 12:37:33 PM
Roof Plan Issues- lower roof showing above upper roof
Thu, Dec 10, 2015 at 3:10:46 PM
Page generation time: 1.0559
