27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Align Cut pattern to Roof (Section)
Is it possible to align pattern to 2 different referance points in the same element. In a roof section I want ridgid insulation to be alignd with the roof and I can get it to work with one side but not the other (and I dont really want to break the roof in the middle so that it would).
See attached photo. The right side is correct but the left is all weird and I don't like it.
Not sure if what I want is currenly possible.
Revit 2020
Thanks!
Afaik, it's not possible. You can use vertical or horizontal lines cut pattern - at least both sides will be the same, or use filled region for the side that you don't like.
cut pattern in section |
Wed, Jun 1, 2011 at 4:30:59 AM
Toposurface cut pattern Not showing in section |
Wed, Jan 13, 2010 at 12:51:34 PM
Stiar cut pattern or fill pattern. |
Sun, Feb 19, 2006 at 11:46:36 PM
Cut Pattern in Plan vs Section |
Tue, Aug 25, 2009 at 8:47:59 AM
Method to Align Section view to modeled elements |
Wed, Nov 30, 2016 at 1:06:51 PM
