Forums >> Revit Building >> Technical Support >> turning categories on/off from linked models globally (2019)
Fri, May 15, 2020 at 12:04:20 PM | turning categories on/off from linked models globally (2019)
ledgewood33
i have linked models for my consultants in my arch model. is there a way to turn on/off categories globally? i know you can do this through each view template. i would like to avoid have to do this the numerous times of the many templates that i have. i would like to do this for the entire model.
Wed, Jun 3, 2020 at 9:55:07 AM | turning categories on/off from linked models globally (2019)
tim123
4 Stars: 19 Votes
If the elements that you don't want to display are on a different workset, then they can be controlled in the linked model.
Turning off categories in linked models
Tue, Feb 5, 2008 at 11:28:24 AM
model groups vs linked models (2019)
Fri, Jan 24, 2020 at 10:46:33 AM
View Filters and Linked Models
Tue, Mar 28, 2017 at 7:53:31 PM
Visibility in Nested (Attached) Linked Models
Mon, Nov 4, 2013 at 2:44:29 AM
Annotations accidentally snapped into linked dwg (Imported categories)
Tue, Jul 9, 2013 at 5:53:11 AM
Page generation time: 0.2044
