Forums >> Revit Building >> Technical Support >> from/to room data in door schedule of a host model
Fri, May 15, 2020 at 10:21:52 AM | from/to room data in door schedule of a host model
slayerweb
I am working on a very huge project that is linked with multiple models. I am trying to create a door schedule with from/to room data in host model and it results blank for from and to data cells.
I am using revit 2017.1, include elements in links is checked when generating. all other data I extract is ok. Every idea will be appreciated because of a deadline i have in a couple of days.
Fri, May 15, 2020 at 10:43:42 AM | from/to room data in door schedule of a host model
slayerweb
I forgot to mention, phases are same between schedule and links.
Fri, May 15, 2020 at 10:47:42 AM | from/to room data in door schedule of a host model
To include project information from a linked model, for Select Available Fields From, select Project Information. Add the desired fields from the Available Fields list to the Scheduled Fields list.
BTW - that would mean rooms as well.
Door schedule parameters not displaying "room names" from linked revit model.
Fri, May 15, 2015 at 1:22:11 PM
automating door schedule ( From room # To Room #)
Thu, Jun 20, 2019 at 2:14:07 PM
Host wall thickness, in door schedule.
Fri, May 31, 2019 at 4:26:18 AM
room names not being picked up in door schedule
Mon, Apr 21, 2008 at 10:26:48 AM
Door Schedule
Fri, Aug 17, 2012 at 7:07:50 AM
Page generation time: 4.8938
