Forums >> Revit Building >> Technical Support >> exporting revit file to Autocad and layers are not correct
Thu, May 14, 2020 at 4:42:37 PM | exporting revit file to Autocad and layers are not correct
elizabethpetermathew
Hello,
I am trying to export a revit plan to autocad. But revit exterior wall finish does not go to the A-FNSH finish layer that is preset in the Revit export settings. I would like to studs to be on a separate layer once exported into AutoCAD. The preset settings in the export window in revit shows all correctly, but once I open the file in AuroCAD the exterior finish layer does not appear and the studs and substrate layer are the sameA-wall. The finish is on I-wall. Please tell me what am I doing wrong. This urgent. Thank you in advance.
Wed, May 20, 2020 at 7:53:16 AM | exporting revit file to Autocad and layers are not correct
marmiketin1
4.5 Stars: 10 Votes
Have you set your layers up for both the projection and cut portions of the export standards. Are you working from a standard you have already setup in revit or are you just altering the in session settings? You also need to make sure that Walls/Interior and Walls/Exterior are set up correctly and that you export using categry properties by Layer and overrides by entity.
Fri, May 22, 2020 at 12:02:49 AM | exporting revit file to Autocad and layers are not correct
oskokos
Attach a screenshot or Revit file. Without it, it's hard to understand what you are doing wrong.
Fri, May 22, 2020 at 12:51:37 PM | exporting revit file to Autocad and layers are not correct
Hello,
See attached snapshot imags, one from revit export layers and the other showing layers from the CAD exported file.
Teh revit settings do nto seem to be translated correctly durign th exporting process. Thank you.
Fri, May 22, 2020 at 9:53:49 PM | exporting revit file to Autocad and layers are not correct
oskokos
I tried to do it myself. I also have not correctly divided into layers. Maybe a bug?
Exporting Revit generic annotations to specific layers in Autocad. Help!
Wed, Nov 7, 2012 at 5:44:24 PM
Changes to AutoCAD layers when imported to Revit
Wed, Oct 29, 2008 at 10:35:39 AM
Dimension issues when exporting to AutoCAD
Mon, Nov 19, 2007 at 4:51:13 PM
AIA Standards- Revit to AutoCAD layers
Thu, Feb 1, 2007 at 12:50:29 PM
exporting to autocad
Fri, Aug 31, 2012 at 7:35:41 AM
Page generation time: 6.2896
