Forums >> Revit Building >> Technical Support >> Roof finish to turn at eaves, rake and fascia
Tue, May 5, 2020 at 12:16:57 AM | Roof finish to turn at eaves, rake and fascia
elizabethpetermathew
Hello,
We are modeling a standing seam metal roof that will have  the vertical seams continue into the eave. This will appear in the Revit model and the rendered view. How can I make this adjustment in the model material? The finish that is applied does not appear at eaves or rake. See attached.
Thank you.
Tue, May 5, 2020 at 7:14:24 AM | Roof finish to turn at eaves, rake and fascia
I'm lost.....?
Not sure what you mean by into the eaves and rake.  The roof should extend over the eaves and over the rake.  But typically, it does not over the face of thes or under them.
Have you built your roof correctly so that it does that?
Tue, May 5, 2020 at 9:05:10 AM | Roof finish to turn at eaves, rake and fascia
marmiketin1
4.5 Stars: 10 Votes
If I am understanding correctly you are wanting the metal roof to go down the fascia? You can accomplish this by going to Modify Tab -> Geometry -> Paint and select the material you want and then paint the edges of the roof. You can then align the patterns how you need.
Tue, May 5, 2020 at 6:04:23 PM | Roof finish to turn at eaves, rake and fascia
Yes I want the roof finish in rendered image to go down the eave edge, rake and soffit. So it appears as one continuus finish. CAn I use the paint command for renderings? My rendered image of the roof is a jpeg file. Thank you.
Tue, May 5, 2020 at 6:29:22 PM | Roof finish to turn at eaves, rake and fascia
Come on now....one of the great things about Revit or even CAD is you can try something and go backwards if needed.  If you never learn that, then you will learn very lettle else.
Wed, May 6, 2020 at 1:23:34 AM | Roof finish to turn at eaves, rake and fascia
Great thank you, it worked!
Wed, May 6, 2020 at 5:50:35 AM | Roof finish to turn at eaves, rake and fascia
GenByle
How did you make such a roof?
Wed, May 6, 2020 at 6:02:07 AM | Roof finish to turn at eaves, rake and fascia
oskokos
- Architecture - roof - roof by footprint
Check Defines Roof Slope like on a picture
Enjoy Smile
Wed, May 6, 2020 at 6:05:50 AM | Roof finish to turn at eaves, rake and fascia
GenByle
how did you make the walls?
Wed, May 6, 2020 at 5:56:54 PM | Roof finish to turn at eaves, rake and fascia
Not sure I understand the question. The image of the standing seam roof finish is part of the rendered appearance of the roof finish (took scan of the roof finish and cropped it) and the walls have 1/2" reveals on stucco.
These are tonwhomes, each is a linked model.
Sat, May 9, 2020 at 9:36:26 PM | Roof finish to turn at eaves, rake and fascia
#11
oskokos
"how did you make the walls?" - Select wall and click ATTACH TOP/BASE
If you want to learn how to make roofs, check out this example file with different roofs: https://measuredsurvey365.co.uk/revit-roof-forms/
Adding fascia to curved roof.
Mon, Dec 13, 2010 at 9:21:59 AM
Revit 2012 fascia limitations??
Sat, Oct 12, 2013 at 2:06:35 AM
exposed rafter tails
Mon, Aug 4, 2008 at 7:38:57 AM
Trouble with join geometry with Roof fascia
Fri, Oct 18, 2013 at 10:26:02 AM
Gable End Rake Detail
Tue, Jun 27, 2017 at 10:11:04 AM
Page generation time: 1.3109
