Forums >> Revit Building >> Technical Support >> material pattern related in revit 2021
Mon, Apr 13, 2020 at 4:58:57 AM | material pattern related in revit 2021
gkrajwaria
hi i am facing a issue using revit 2021. when i am applying material, material pattern is not visible in revit model neither in consistent color nor in realistic mode. when i open material tab, i found a yellow error mark on materials.
kindly suggest me any solution i am attaching ralated images for more ...
thanks
Tue, Apr 14, 2020 at 8:45:37 AM | material pattern related in revit 2021
marmiketin1
4.5 Stars: 10 Votes
You need to show more information. The 2 images you posted just show the graphics and there is currently no material pattern assigned. The yellow tick mark on the material just means that the material was created in a previous version of revit before the current material overhaul was done which updated the way materials render. It added the sections cutouts and transparency which allow you to use an image to dictate these things in addition to the already present bump and general texture images present in the older versions of revit.
Wed, Apr 15, 2020 at 4:27:26 AM | material pattern related in revit 2021
gkrajwaria
please find attachment as you asked in last mail. here are 5 images attached. i am facing same issue  i am using only revit 2021 student version. when i am applying material, material pattern is not visible in cosistent color/realistic revit model view. when i am adding material in library than issue is same.... and to add material  when i check image location that is C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\3\Mats. if i rename any image n this location, image will get disappear.
Wed, Apr 15, 2020 at 10:26:06 AM | material pattern related in revit 2021
Quit refreshing your post.  Everytime you do so, it results in a duplicated post.  I have already deleted 5 of these.  If you continue to do this, you may be banned.
Pattern scaling relative to views
Thu, Nov 13, 2008 at 10:40:19 AM
Wall Structure Type
Thu, Jun 23, 2022 at 11:34:46 PM
hatch pattern in material anomolies
Fri, Aug 26, 2016 at 9:35:26 AM
Where is pattern setting in material browser
Thu, Jul 26, 2018 at 1:52:03 PM
Surface Pattern Material Problem
Sun, Dec 11, 2011 at 11:30:02 AM
Page generation time: 2.7932
