Forums >> Revit Building >> Technical Support >> sloped steel?
Thu, Jun 8, 2006 at 1:33:50 PM | sloped steel?
sweetiedarling
hello all - how do i slope steel beams for a roof? i can angle the steel around its cross section, but i can't figure out how to rotate the length of the steel. how thoughts? thanks so much!
Mon, May 18, 2009 at 7:02:41 PM | sloped steel?
Tim130
Hi
 Does any one have a solution to previous question, I would like to have the sloping steel which is shown connecting to the beam and the column, can this be cut in any way... I am am using Revit 2009, Cheers
Mon, Mar 29, 2010 at 9:01:20 AM | sloped steel?
testoni1977
Cut the beam with a reference plane should work, see link
http://www.augi.com/publications/hotnews.asp?page=899
Tue, Mar 30, 2010 at 6:52:17 PM | sloped steel?
my68spit
- in a section view or elevation, draw a reference plane along the slope that you want.
- name it something pertinent (Slope @ north vestibule)
- In your "Home" menu, set your plane to the reference plane you just created.
- In plan view, draw your beam.
 - Done.
Hope this helps if you haven't figured it out by now.
Thu, Apr 8, 2010 at 12:32:21 PM | sloped steel?
eveline
The slope of your beam can be determined by the parameters Start level offset and end level offset.
I would like to know how to "trim" sloped beams  that are in a vertical plane.
Eveline
Thu, Apr 8, 2010 at 12:44:00 PM | sloped steel?
my68spit
Eveline,
I am not sure what you are asking.  Which of the member sin the attached image are you trying to "trim"?  Are you wanting to modify the whay that they are joining together at the ridge?  Or you want to trim them on a vertical plane at the horizontal members?
Thu, Apr 8, 2010 at 2:24:46 PM | sloped steel?
eveline
Both, I want to control the way the beams are joined at the top of the roof and the way they connect to the horizontal beam.
Thu, Apr 8, 2010 at 5:51:25 PM | sloped steel?
Sven
3.5 Stars: 3 Votes
I realise that this may be a long way around, and it doesn't actually allow you to join beams, but this will make it look visually correct. Try using the opening tool ('modify'>'openings'>'opening on face') - select the face of the beam, then draw the shape of the cut... like i said, its not necassarily the fastest method, but you can copy the cut profile between beams.
Alternatively, you could create your own beam family with a sloping cut on it.. there is a timber one in the download section of this site.
Good luck!
True plan view of sloped steel?
Mon, Feb 27, 2017 at 9:31:22 AM
14
Double Sloped Steel Joist
Thu, Dec 23, 2010 at 8:35:13 AM
Roof to follow sloped structural steel
Wed, Sep 22, 2010 at 4:11:16 AM
Applying a timber surface to a sloped steel roof?
Thu, Aug 14, 2008 at 11:22:43 AM
Need Help on Sloped Beam-Column Connection
Fri, Apr 29, 2016 at 1:50:43 PM
Page generation time: 0.8508
