Forums >> Revit Systems >> Technical Support >> some pipe fittings and piping now showing below floor
Wed, Apr 8, 2020 at 2:52:26 PM | some pipe fittings and piping now showing below floor
vinnygolfer
4.5 Stars: 4 Votes
Hi all, we're working on a project that is revit 20, and with BIM 360. for some reason when drawing the sanitary below floor some of the elbows show up and some don't. also some of the piping shows and some is hidden. we have checked the view range and it's set up correct. would it effect the plumbing model if another trades model that is linked in through 360 has a plan region that is effecting the view? I'm a a loss right now. we have looked at the hidden items and everything.
any thoughts?
Try to learn at least one new thing every day
Thu, Apr 9, 2020 at 6:45:56 AM | some pipe fittings and piping now showing below floor
vinnygolfer
4.5 Stars: 4 Votes
I found the problem. It was a plan region blocking parts of the piping system. I don't know why the plan region borders always get turned to hidden in the views. the only way to edit them is to find them in the reveal hidden objects tool.
Thu, Apr 9, 2020 at 6:46:13 AM | some pipe fittings and piping now showing below floor
vinnygolfer
4.5 Stars: 4 Votes
Has anyone had issues using Charlotte pipe families for piping in 2014?
Fri, Nov 1, 2013 at 9:14:27 AM
18" (450mm) storm piping & related fittings
Fri, Apr 17, 2009 at 5:16:01 PM
Labeling/Schedule Piping per Room Location
Mon, Jun 23, 2014 at 6:54:45 AM
Pricing Pipe Fittings
Tue, Sep 14, 2010 at 3:10:59 PM
How to get pipe fittings to appear as simple pipe lines?
Thu, Mar 20, 2014 at 4:40:08 PM
12
Page generation time: 2.0404
