Forums >> Revit Building >> Technical Support >> Problems when printing tp PDF using shadows
Sat, Mar 21, 2020 at 7:41:02 AM | Problems when printing tp PDF using shadows
GLKIRK
I have been working on this problem for a while and decide it is more of a printing issue than a Revit issue.
Does anyone know how to not have the whole view print so faint?
I can't figure out what it means to use Control bar at bottom left of the view window?
I use 2020
Thanks!
160198_Bottom_left.png160198_Elevation_with_shadows.png160198_Elevations_without_shadows.png160198_Vector.png
Sat, Mar 21, 2020 at 8:14:51 AM | Problems when printing tp PDF using shadows
Raster printing will always give you lighter prints but typically not as light as you have shown us.  I always used Cutepdf as you are and not seen this much difference.
If you look at similar threds below, some people used DWF then to PDF.
Edited on: Sat, Mar 21, 2020 at 8:16:08 AM
Sat, Mar 21, 2020 at 9:58:30 AM | Problems when printing tp PDF using shadows
GLKIRK
Thanks WWHub,
In learning how to export to DWF, all I can seem to get is this squigly line mess.
I have tried many different settings to still only get this.
Any thoughts?
Edited on: Sat, Mar 21, 2020 at 11:03:29 AM
Printing Shadows in .pdf file - Revit 7.0
Wed, Dec 22, 2004 at 9:16:23 AM
Printing with Shadows on and PDF
Wed, Jun 3, 2009 at 1:54:17 PM
PDF printing problems
Tue, Dec 3, 2013 at 7:16:18 AM
shadows, many problems
Mon, Jul 11, 2005 at 10:30:06 AM
Black lines printing grayscale in PDF
Fri, Oct 10, 2014 at 4:46:46 PM
Page generation time: 0.2133
