13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> I-joists
I can't get i-joists to show up in drawing with thins lines, only very heavy lines. I select a joist, edit family, select outline of joist, under vg,
select edit, select detail level ---fine, vg---object styles, select lt lines, load into project, still have very heavy lines. See attachments.
I'm stuck!
Did you look at the vg settings in your view? Those can over-ride family settings.
I did the vg override but no change in the line weight.
No, that is not what I was talking about. VG Setting for the view.
https://www.youtube.com/watch?v=BAwoR4pzOuQ
Sloping joists to the roof deck |
Mon, Apr 4, 2016 at 11:21:15 AM
joists |
Thu, Oct 11, 2007 at 4:43:14 PM
JOISTS ON BEAM DISPLAY REPRESENTATION |
Fri, Dec 19, 2008 at 10:38:03 AM
Sloping Bar Joists? |
Thu, May 7, 2009 at 9:41:08 AM
Adding roof bar joists on different hight brg. ends.. |
Fri, Oct 9, 2009 at 12:02:50 PM
