17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Topo Surface From CAD Import
Hello! First time posting, hoping a Revit genius out there can help me out
I've created a toposurface from a CAD survey & lined it up where it needs to be with our building (which I had already modeled).
The project & survey points are in the right spot (I think), so that we have our finish floor (0'-0") actually landing at 228'-4" (desired actual elevation; please see first three images attached).
The problem is, the topo elevation points are reading in the - 450's (see fourth image attached).
Am I missing something obvious? I'd like the topo to be accurate aka in the 220's as it appears to be looking at the section, but it is not reading correctly (which means all my topo lines will be labeled wrong)
Thanks in advance for your help!
-Kayla
Couple of things - note that levels and elevation markers can be set to Project or Survay base point. With reference to your images, you can relocate the project upwards so that it is in the correct position.
Importing topo surface from CAD in Revit |
Fri, May 1, 2015 at 7:28:19 AM
Import topo surface from AutoCAD to Revit?? |
Thu, Oct 17, 2013 at 12:49:05 PM
topo contours are offsetting in z direction |
Fri, Mar 27, 2015 at 5:42:45 PM
Civil 3d surface to revit topo surface |
Thu, Oct 13, 2011 at 7:14:34 AM
Has anyone find an accurate way of creating topo Surface from import |
Tue, May 29, 2012 at 7:42:09 AM
