Forums >> Revit Building >> Technical Support >> WINDOW TAGS
Wed, Feb 12, 2020 at 1:20:39 PM | WINDOW TAGS
integrity
The marks in the window schedule do not appear correctly in the tags on the floor plan.
I'm using Revit 2020LT.
Wed, Feb 12, 2020 at 2:19:56 PM | WINDOW TAGS
marmiketin1
4.5 Stars: 10 Votes
Open your schedule, then got to Properties --> Fields --> Edit and make sure your first field is referencing MARK and not TYPE MARK. Since your sencond image shows the two windows both having the same value I will assume that currently it is referencing the TYPE MARK which is a type parameter whereas MARK is and instance parameter.
If that is not the case then it might be your tag is referencing the TYPE MARK and needs to be changed to MARK. You need to do this in the family editor and select the label and change its properties.
Edited on: Wed, Feb 12, 2020 at 2:21:35 PM
Wed, Feb 12, 2020 at 3:08:10 PM | WINDOW TAGS
integrity
I can select a tag, then mode, then famitly editor. I get a picture of the tag but no dialog to change parameters.
Thu, Feb 13, 2020 at 12:20:54 PM | WINDOW TAGS
marmiketin1
4.5 Stars: 10 Votes
See attached image for process to change window tag associated parameter
Window Tags not working
Fri, Sep 24, 2010 at 7:30:45 PM
window tags in elevation
Tue, Feb 13, 2007 at 12:51:56 PM
Door and window tags
Thu, Nov 3, 2011 at 8:51:34 AM
Room Window and Door Tags
Thu, Nov 15, 2007 at 9:21:10 PM
Window tags not showing
Thu, Sep 28, 2006 at 1:10:48 PM
Page generation time: 0.9547
