14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> 2020 revit - doors not recognizing rooms in a phased project
0 Posts No Rating |
I have a phased project (3 phases) and none of the doors are recognizing the rooms. The error message keeps mentioning there is no room information with the door. I checked the door families and the Door Location in ticked on showing the swing to or from arrow. The arrow is long enough to be in each room. The Door Schedule will show no room name or any"To" or "From" room information.
Room schedule picks up the room names and numbers. I thought maybe the actual rooms need to have the same phase assigned to them as the doors but you cannot assign phases to the rooms.
I have searched various forums but everyone seems to suggest the same thing, make sure the door location tick is on in the door family. Any help would be greatly appreciated.
Rooms are absolutly phase specific. Read this:
http://help.autodesk.com/view/RVT/2016/ENU/?caas=caas%2Fsfdcarticles%2Fsfdcarticles%2FRevit-How-to-show-rooms-and-room-tags-in-different-phases.html
0 Posts No Rating |
Hello WWHub,
Thank you for the link. Yes, I finlly figured all of that out with some great help from another forum here. They brought up some good points that I was not even thinking about plus I found out there was some user error on my side so there is that.
Edited on: Thu, Feb 13, 2020 at 9:54:42 AM
How to Tag all rooms at the same time |
Thu, Feb 4, 2021 at 11:25:29 AM
project set-up - needed/wanting to use/link the same model 2x within project |
Thu, Aug 4, 2011 at 6:09:53 AM
Importing IFC into Revit 2020. Windows/Doors not showing in plan/elevations/sect |
Tue, Feb 4, 2020 at 6:15:58 PM
AutoCAD translation file for phased project |
Tue, Feb 24, 2009 at 2:32:39 PM
Door Schedule Problem - All Room Fields are Blank |
Thu, May 30, 2013 at 7:40:46 AM
