11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Connect Into Setting
Hello Revit City!
Im wanting to use Connect Into command use mechanical equipment. But I do NOT want it to connect the equipment to the pipe using solid pipe. I want it to connect using flex pipe. But I dont know how to change the default Connect Into setting.
Any ideas?
Thanks!
See:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Revit-Model/files/GUID-DA98A929-459F-4683-8F0D-A8FBE63BEA95-htm.html
and
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit-Model/files/GUID-4AD9ABB4-B96F-45C5-8AB4-E86D76D20E3D-htm.html
I saw these but they dont address what I was looking for.
If you select a mechanical equipment, choose connect into, select a pipe. This will model a pipe from the equipment to the other pipe. How do I change that so when I choose connect into it models flex pipe instead?
Flex pipe is just pipe.... Did you follow through on the sub topics and read theis?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Revit-Model/files/GUID-7E29FD4C-4277-4B47-8906-25008B0269FD-htm.html
I have looked through all of it. I dont see how to change the connect into default pipe. What am I missing? Can you be direct?
I think you have to end your solid piping with the flex at the end. Then the fixture should automatically connect to the flex.
connect to existing [ 1 2 ] |
Fri, Aug 17, 2012 at 9:59:38 AM
20
Familiar in ADD in- Software - Revit SDS/2 Connect |
Thu, Aug 8, 2013 at 1:17:41 AM
Connect cameras for animation |
Sat, Sep 29, 2007 at 12:45:17 PM
Beams Wont Connect |
Tue, Nov 12, 2019 at 10:47:06 AM
Cannot connect to www.revitcity.com |
Tue, Jul 13, 2010 at 2:15:59 AM
