Forums >> Revit Building >> Technical Support >> pipe annotation tolerance
Thu, Jan 2, 2020 at 9:23:48 AM | pipe annotation tolerance
hanbyjm
Revit 2019.2 I have a 1 1/2" diameter pipe that is labeling 2" diameter.  Is there somewhere to set the tolerance for tags so it shows the correct diameter?  New to piping systems.
Thu, Jan 2, 2020 at 2:21:35 PM | pipe annotation tolerance
Look at your own image above what is circled.  There is another parameter that is 2".  What parameter is your tag reading?
Unit tolerance
Thu, Jan 21, 2010 at 5:12:10 PM
2D nested annotation symbol doesn't show when family is sloped in 3D
Tue, Aug 2, 2011 at 2:58:56 PM
room bounding tolerance
Mon, Mar 8, 2010 at 2:30:54 PM
Trim HSS Round pipe into another HSS Round pipe
Tue, Apr 3, 2012 at 4:39:45 AM
Pipework Annotation Scales
Fri, Feb 22, 2013 at 5:17:01 AM
Page generation time: 0.0858
