Forums >> Revit Building >> Technical Support >> Can't unpin a view
Fri, Dec 13, 2019 at 1:51:14 PM | Can't unpin a view
glenlake
3.5 Stars: 3 Votes
Hi all,
please help me to unpin a plan view. Revit 1018, no worksets, no design options, nothing.
When select a plan view in the browser, get a message that I should unpin the elements first.
The instance ID is that of the view.
The viewframe is selectable and not pinned.
Thanks
Sat, Dec 14, 2019 at 8:33:50 AM | Can't unpin a view
Do the unpin from the sheet where the view is locked in place.
Mon, Dec 16, 2019 at 8:53:05 AM | Can't unpin a view
glenlake
3.5 Stars: 3 Votes
This view is not on sheets. I checked them all.
Mon, Dec 16, 2019 at 12:55:13 PM | Can't unpin a view
Do you have "Select Pinned Elements" turned off?
Tue, Dec 17, 2019 at 4:48:43 PM | Can't unpin a view
glenlake
3.5 Stars: 3 Votes
I can select pinned elements. I ve selected all what possible and unpinned.
Wed, Dec 18, 2019 at 1:54:58 PM | Can't unpin a view
Something is wrong with the file or the view so just recreate it.
Fri, Dec 20, 2019 at 11:13:38 AM | Can't unpin a view
glenlake
3.5 Stars: 3 Votes
I've made a view based on the same level. It works well. You are right, the old view is probably corrupted. I cannot figure out what is "PINNED". But the project is big and I need to delete all what's possible.
Thank you again
Wed, Apr 15, 2026 at 8:25:06 AM | Can't unpin a view
Yousafali0254
You can delete pinned views using the DiRoots View Manager add-in.
Pinned walls in 2014 can't UnPIN Walls
Wed, Oct 15, 2014 at 3:33:17 PM
Beam system, cant offset?
Fri, Feb 13, 2009 at 8:16:03 AM
Problem with 'Coarse' & 'Fine' view options
Thu, May 16, 2013 at 2:07:40 AM
View Labels and Bubbles are gone?
Mon, Jan 23, 2006 at 12:16:57 PM
'Activate View' on sheets
Tue, May 7, 2013 at 11:26:56 AM
Page generation time: 0.7183
