Forums >> Revit Building >> Technical Support >> R2020 - issues with Transmit a Model
Thu, Dec 12, 2019 at 12:00:40 PM | R2020 - issues with Transmit a Model
iamian33
iamian33 Avatar
Greetings
We are about to upgrade all our active projects from R2019 to R2020.  We used Transmit a Model in the past but now in R2020 Transmit a Model sets the Open workset default to “Specify”.  This is a problem for us, we prefer the setting “All”.
The only way I know to adjust this setting is to detach each model and change this setting.  Is there another way because it will be very time-consuming to correct?  Please advise …
Thank you.
Ian Shafer
Principal Consultant
True North S&F Consultants
Archiving
Fri, Jun 26, 2009 at 11:33:31 AM
pdf program
Thu, Jan 20, 2011 at 1:38:35 PM
R2020 - Glass Railing
Fri, Jan 24, 2020 at 10:36:28 AM
E-transmitting in revit?
Mon, Dec 17, 2007 at 7:04:21 PM
PDF File Names
Thu, Apr 7, 2011 at 8:37:37 AM
Page generation time: 5.0602
