Forums >> Revit Building >> Technical Support >> Interior Elevation Reference Custom Parameter (Versions 2017-20)
Mon, Dec 9, 2019 at 12:19:11 PM | Interior Elevation Reference Custom Parameter (Versions 2017-20)
acooleyWPA
I've created a elevation family for my firm, that is more like what we have used in AutoCAD.
We place the 4 elevations under one view title and have a custom (hacked) shared parameter called "view # on sheet" this shows up on the view title and the elevation bubble.
All seems to work just fine and the firm has accepted this new work around.
One Problem, When i reference an interior elevations (when i have mutli view that are similar), the custom shared parameter doesn't propagate to the referece properites.
I'm looking for a way to either propagate the existing custom shared parameter, or to create a new parameter that works in the Reference properties.
I'll share my revit family in a comment below.
159954_ELEVATION_BUBBLE.PNG159954_ELEVATIONS_UNDER_ONE_TITLE_BAR.PNG159954_PROPERTIES.PNG159954_REF_BUBBLE.PNG159954_REF_PROPERTIES.PNG
Mon, Dec 9, 2019 at 12:31:30 PM | Interior Elevation Reference Custom Parameter (Versions 2017-20)
acooleyWPA
Here is my Elevation Family
Wed, Dec 18, 2019 at 12:30:08 PM | Interior Elevation Reference Custom Parameter (Versions 2017-20)
acooleyWPA
TEMP workaround
under annotations - select 'view reference'
I created a family that looked like my interior elevation symbol (w/o the arrows), this had the same parameter as the interior elevations and would update when you change that parameter on the sheet/elevation/etc.
then i overlap that view reference bubble with an adjustible arrow so i can point at the correct wall.
seems like a lot to do, so hopefully will find an easier way.
Multi-view Elevation - Reference SIM
Fri, Mar 9, 2012 at 8:40:42 AM
spot elevation & custom pipe tag
Mon, Mar 24, 2014 at 10:29:52 AM
View/ Interior Elevation Legend
Tue, May 12, 2009 at 12:58:01 AM
Interior Elevation Reference Label
Fri, Jun 18, 2010 at 2:58:09 PM
Interior Elevation Tags
Mon, Jul 21, 2025 at 11:28:06 AM
Page generation time: 1.3389
