Forums >> Revit Systems >> Technical Support >> Message when opening file
Thu, Nov 14, 2019 at 3:33:05 AM | Message when opening file
lanskaja
Hello!
When I open model, Revit (2019) gives me a message "Impossible open current view". After I change view I can look the same message.
Please help me to solve tis problem.
Fri, Nov 15, 2019 at 8:28:18 AM | Message when opening file
adoifjmamc2
adoifjmamc2 Avatar
4 Stars: 4 Votes
What type of model is it?
adoifjmamc forever
Wed, Nov 27, 2019 at 7:47:08 AM | Message when opening file
lanskaja
When I open project, Revit dave the message:
"An error has occurred while drawing the contents of this window. This window shall be closed".
What the reason of appearance of this message?
Wed, Nov 27, 2019 at 1:00:39 PM | Message when opening file
The window closing message typically indicates a corrupt Revit file.  You may have to use a backup.
The second message is from the Revitcity server and has nothing to do with your Revit file.
File not opening!
Thu, Dec 27, 2007 at 9:15:48 AM
how do I load cased opening and arched openings
Wed, Sep 28, 2011 at 3:05:58 PM
REVIT 2015 DELETE FAMILIES FROM FILE BEFORE OPENING IT - UNRECOVERABLE ERROR
Thu, May 12, 2016 at 7:57:15 AM
Opening 2008 file in 2009 causes "Unrecoverable error" crash
Tue, Jul 28, 2009 at 1:36:33 AM
Vista 32, Revit Arch 09, file opening issue
Thu, Feb 12, 2009 at 3:24:23 PM
Page generation time: 0.4919
