Forums >> Revit Building >> Technical Support >> grouping and phasing- is there a better way?
Thu, Oct 31, 2019 at 6:16:32 PM | grouping and phasing- is there a better way?
dar8
Hi all,
General question that came up in working on my specific project. Basically it's a multifamily housing renovation, so we have a bunch of typical units (that's one group, repeated all over) and a few special units (that each have their own group, one on every floor). We need to show demo plans and (new) plans. So in the typical unit group there are some things that stay the same (phase created: existing, phase demolished: none). SO that's easy, makes sense.
But then there are the other things that are being torn out and replaced with pretty much exactly the same thing. What we have is two of that object (range, counter, whatever) in the same spot, phasing one as phase created: existing, phase demolished: new construction and the other as phase created: new construction, phase demolished: none. And we have the view templates for the plans set to show previous and new (new construction) or show previous and demo (demo plan).
A) Is there a better way to accomplish this?? Surely renovations are something that architects do often, so why doe it feel like a Revit workaround? (Sometimes we link in the units instead of using groups, if that makes a difference. But, otherwise it's the same.)
B) So now I am going into every single group and changing the phases of every single family. If anyone knows a magical way to change the phasing of an object *in every group instace* please please share it!
This project is in Revit 2018, but we work in 2019 as well.
THANK YOU
Wed, Nov 6, 2019 at 2:58:09 AM | grouping and phasing- is there a better way?
tim123
4 Stars: 19 Votes
Can't you just select one and press SA (select all)?  This should still find the instances within all the groups.
You might make it easier for yourself if you give the new item (range, whatever) a different name to the old one so that they can be identified more easily.
Phasing and grouping?
Tue, Dec 5, 2006 at 9:32:21 PM
Phasing - Building Already Done but Dind't Set up Phasing
Tue, Dec 15, 2009 at 7:40:42 AM
Grouping Floors
Mon, Aug 22, 2005 at 3:47:49 PM
Graphical Column Schedule - Not Grouping all similar instances
Wed, Nov 5, 2008 at 11:11:18 AM
phasing
Tue, Oct 23, 2012 at 8:20:21 AM
Page generation time: 0.8098
