Forums >> Revit Building >> Technical Support >> Overriding grids of a linked model in view
Sun, Oct 27, 2019 at 4:36:33 PM | Overriding grids of a linked model in view
glenlake
3.5 Stars: 3 Votes
Dear experts,
what's the best way to override in view the grids of a linked model without using filters? Why does VV/ Links / Custom / Annotations /Custom not work?
Revit 2017.
Thank you.
Mon, Oct 28, 2019 at 5:41:08 AM | Overriding grids of a linked model in view
Just turn them off in VG.
Mon, Oct 28, 2019 at 8:38:49 AM | Overriding grids of a linked model in view
glenlake
3.5 Stars: 3 Votes
Thanks.
But how to override them? Say, I want to have my link's grids to be thick, red and of solid line pattern?
Mon, Oct 28, 2019 at 5:21:37 PM | Overriding grids of a linked model in view
I am lost here.  Why would you even want the linked fil's grids on?  Without you saying otherwise, we would all think your grids are there and no need for the linked grids.  If these are different grids than yours because they are not in the same building, then you should say so.
Tue, Oct 29, 2019 at 4:30:29 AM | Overriding grids of a linked model in view
Shatner86
Shatner86 Avatar
5 Stars: 2 Votes
hi Glen,
You could edit the Type Properties of the grid family in your link? I don't think you can make them thick but you can make them red and solid lined.
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein
Wed, Oct 30, 2019 at 10:46:45 AM | Overriding grids of a linked model in view
glenlake
3.5 Stars: 3 Votes
Thanks again. I thought about something like that -- to override the grids' type properties.
But our consultants sometimes change their model location (maybe they don't use our shared coordinates correctly), and i have to relocate their model. I i override the grid properties, they  will be the original ones after i update their model.
I just want to have our grids as thety are, and their grids red.
IFor now, i do opposite -- override our grids and keep their grids (and levels) as they are.
I think to override their levels and grids would be more straightforward.
overriding materials for linked model revit
Wed, Jun 22, 2016 at 7:29:03 PM
Copy Monitor Grids
Tue, Feb 3, 2015 at 8:20:16 AM
Linked Model Showing In 3D View Only
Tue, Aug 5, 2014 at 1:11:42 PM
Visibility in Nested (Attached) Linked Models
Mon, Nov 4, 2013 at 2:44:29 AM
Can't Get Copy Monitor to Work for Grids and Levels
Fri, Feb 21, 2014 at 4:55:28 PM
Page generation time: 6.2185
