16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Some beams don't appear from one side.
0 Posts No Rating |
Some of my beams (the red lines i drew) don't appear from "West Elevation" look. And visibility is set as "Fine". Do you have any idea what may cause that ?
0 Posts No Rating |
Ops, i mean from "East Elevation"
Make sure elevation cut line is in font of your building, not cutting through it.
0 Posts No Rating |
Oh, yes it fixed the problem. Thank you. Are there cut options for floors, too ?
I'm not sure what you're asking for. Can you explain? What are you trying to do?
0 Posts No Rating |
For example, it shows a floor plan from level 1. Let's say our level 1 starts from 0 cm and ends at 300 cm. So does it cut from 100th cm ? 150th cm ? So i asked if there was an adjustment for cutting height for each level, too.
Read this: http://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-58711292-AB78-4C8F-BAA1-0855DDB518BF
Beams that are copied are invisible, while beams placed can be seen?? |
Sat, Jan 20, 2007 at 9:53:43 AM
how are joined beams and floors in 3d view? |
Mon, Jun 27, 2005 at 6:54:40 AM
Columns/Beams won't cut wall & wall beyond is visible |
Thu, Jun 21, 2012 at 9:19:31 AM
Boxing beams |
Wed, Aug 24, 2011 at 6:10:16 AM
Steel Beams |
Thu, Aug 4, 2005 at 8:46:03 AM
