14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> ADA Sign - Text not showing
I have an ADA sign that I have been modifying. I needed the sign to read "Men Shower" but when I place it. The text does not show up. See attachment. When I highlight the sign, the text shows up. Any help would be appreciated. Thanks.
The text is not associated with any work plane, that’s why it is not moving with the sign when the wall thickness changes.
In your family, select text, click on Edit Work Plane (ribbon) and select Wall Edge from the pull down under Name.
Thank. I know I was overlooking something simple.
Rendering Text |
Wed, Dec 10, 2008 at 4:47:01 PM
Parametric Exit Sign |
Mon, Apr 14, 2014 at 12:38:11 PM
13
Accidental Backwards Model Text |
Fri, Jun 5, 2020 at 11:59:29 PM
Trying to make a non ADA ramp but always have problems with railings, need help! |
Wed, Oct 16, 2013 at 9:10:43 AM
Text On A Retail Sign |
Fri, May 6, 2005 at 3:21:58 AM
