29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Room boundary issue
Hi! I am placing rooms and tags on my plan and some of the rooms boundaries appear wrongly. It looks like the boundary does not see the wall and takes the next room's area too. Any thoughts? Revit 2019
Look at the wall properties, is room bounding turned off?
Does the wall go to the level the room is placed on?
All is fine, the room bounding is on. What I did is I allowed the wall connection (intersection) which is not good but at least room boundaries work. After I place the finishing I will have to break the wall connections again. But for the moment I solved the issue (probably not the best solution). Thanks.
Room Boundary Issue [ 1 2 ] |
Tue, Sep 11, 2012 at 12:46:42 PM
21
Room Boundary Issue |
Sat, Feb 16, 2013 at 4:33:13 AM
Structural column doesn't define room boundary (but only sometimes!) |
Wed, Apr 1, 2015 at 10:23:56 AM
Reshaping Room Boundary |
Tue, Mar 11, 2014 at 3:34:24 PM
Room boundary does not display properly |
Wed, Mar 27, 2013 at 1:51:25 PM
