Forums >> Revit Building >> Technical Support >> HOW TO CREATE SHED TYPE ROOF IN COMPLEX/TRAPEZOIDAL FLOOR PLAN
Wed, Sep 18, 2019 at 11:41:09 PM | HOW TO CREATE SHED TYPE ROOF IN COMPLEX/TRAPEZOIDAL FLOOR PLAN
JoshuaDado
Good day Sir/Ma'am,
I would like to ask how to create shed type roof in this complex floor plan. I tried to create the roof and the result is this (FRONT ELEVATION AND EAST ELEVATION). It has a huge gap between the second roof and the first roof. I want it to look like this (MY SKETCH). I want the two roofs to be on level not slanted. I also attached the floor plan here.
Thanks in advance guys.
159722_FRONT_ELEVATION.PNG159722_702478314827380892361594337815135285411840n.jpg159722_EAST_ELEVATION.PNG159722_FLOOR_PLAN.PNG
Thu, Sep 19, 2019 at 1:00:11 AM | HOW TO CREATE SHED TYPE ROOF IN COMPLEX/TRAPEZOIDAL FLOOR PLAN
Buddhima123
Try to create both roofs seperatly..then you can adjust height..
Thu, Sep 19, 2019 at 6:33:01 AM | HOW TO CREATE SHED TYPE ROOF IN COMPLEX/TRAPEZOIDAL FLOOR PLAN
Your sketch would be true if your roof was square in plan but with the floor plan you show, that would not be the case.  The only way you could get the look of your sketch would be with a mansard front and flat roof behind it or if your lower roof was rectanguler but had one heck of an overhang on the east end.
You need a closure wall on the south side of the high roof area.
Fri, Sep 20, 2019 at 11:10:56 PM | HOW TO CREATE SHED TYPE ROOF IN COMPLEX/TRAPEZOIDAL FLOOR PLAN
JoshuaDado
Thanks Guys!
shed roof with dbl slopes
Wed, Jun 15, 2011 at 8:31:08 AM
unable to create shed roof for curved wall
Sat, Sep 25, 2010 at 4:37:32 AM
Floor plan type
Sat, May 5, 2012 at 7:07:18 AM
Very Very Challenging Complex Roof
Wed, May 24, 2006 at 12:01:41 AM
Shed Roof between non-parrallel walls
Tue, Dec 2, 2008 at 7:02:36 PM
Page generation time: 6.5467
