Forums >> Revit Building >> Technical Support >> Plan Cut Plane on stepped condos
Wed, Aug 28, 2019 at 2:02:38 PM | Plan Cut Plane on stepped condos
omahawildcat
I have Condos that march down a sloped site (20" grade difference between each) Is there a trick to get an overall plan to show a consistant cut plane?
Thu, Aug 29, 2019 at 6:08:28 AM | Plan Cut Plane on stepped condos
Please explain your question furthur.
You do understand plan regions?
Thu, Aug 29, 2019 at 8:39:32 AM | Plan Cut Plane on stepped condos
omahawildcat
If I have a series of condos stepping down a site and my plan view range cut plane is at 4'-0", each plan is going to look different and you may end up cutting through a different floor all together.
Thu, Aug 29, 2019 at 9:40:13 AM | Plan Cut Plane on stepped condos
Use plan regions to redefine your cut plane.
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-594B7B97-0D59-4B03-9544-E403BD03BE48
Generic model cut plane & plan regions
Thu, May 20, 2010 at 6:44:22 AM
Stepped Roof with Overhand
Fri, Oct 25, 2013 at 10:40:43 AM
Cut plane for doors and widows different from plan!!
Wed, Oct 18, 2006 at 8:41:37 AM
window does not get cut in plan view.
Tue, Jul 12, 2011 at 10:37:20 AM
Cut plane problems with Families - Revit 2013
Tue, May 21, 2013 at 2:29:27 PM
Page generation time: 2.1991
