Forums >> Revit Structure >> Technical Support >> Column in revit
Sun, Aug 25, 2019 at 5:38:49 AM | Column in revit
enaries
Hi
I would like to draw a circular tube column with a bend at 30 deg as shown in the attached picture. I tried as a sweep function creating a generic model but when it comes to dimension it, I can not dimension the generic model. Is there any solution or a different way to draw. Your help will be much appreciated.
Regards
Parm
Mon, Aug 26, 2019 at 10:09:12 AM | Column in revit
archimade
helloo
try open new family column project and try crating it by there and try loading it as a family in ur project..
Mon, Aug 26, 2019 at 2:14:47 PM | Column in revit
CDWdavid
5 Stars: 5 Votes
You may use “invisible lines” in that generic model to create all snapping points for dimensioning purpose.
WT column - help?
Fri, Jun 14, 2013 at 9:10:49 AM
DISPLAY COLUMN LABELS
Wed, Sep 8, 2010 at 3:53:41 AM
Column Capitals
Wed, Sep 18, 2019 at 8:39:07 AM
Column Schedule
Mon, Apr 21, 2008 at 7:35:29 AM
Column taking on adjacent fill patterns
Tue, Oct 21, 2014 at 3:56:17 PM
Page generation time: 7.1266
