Forums >> Revit Systems >> Technical Support >> Sanitary fitting isnt working right
Tue, Aug 20, 2019 at 9:46:40 PM | Sanitary fitting isnt working right
dnovember99
hello all. i would say that i am an intermediate Revit user. i have some family creation/modification skills. but when i hit a wall i know that i hit a wall and need to ask for some help. i am now working for a company that is using Revit "right out of the box" so there really isnt any modifications that have been done to any of the families. on the sanitary system when routing pipe i am trying to connect a 4" pipe to a 4" pipe. one is running horizontally and the other is running at 45 degrees. when i connect the angled pipe (shown to the left of the screen shot) into the fitting (shown on the right of the screen shot) the fitting ends up going backwards on me.
is there something within the family that is causing this fitting to do this? i almost want to say that this is taking the fitting from a 90 degree sanitary fitting to 135degree fitting (my math could be totally off.) is there a way to be able to fix this? i also hope that i am making sense.
Wed, Aug 21, 2019 at 5:41:57 AM | Sanitary fitting isnt working right
Always include the Revit year you are using.  This may be an update issue.
This may help you: https://forums.autodesk.com/t5/revit-mep-forum/water-supply-pipe-has-reverse-flow-supplying-each-fixtures/td-p/8052330
Wed, Aug 21, 2019 at 11:19:32 PM | Sanitary fitting isnt working right
dnovember99
i am working in Revit 2018
Sanitary pipes not staying connected anymore
Mon, Sep 26, 2016 at 8:35:10 AM
Change which fitting family is automatically applied while connecting duct?
Wed, Jul 22, 2020 at 11:20:15 AM
Plumbing connection
Wed, Oct 22, 2014 at 2:27:10 PM
duct system types
Fri, Apr 26, 2013 at 7:13:12 AM
Pipe systems getting cross connected
Mon, Dec 21, 2020 at 7:39:25 AM
Page generation time: 0.2269
