Forums >> Revit Building >> Technical Support >> CREATE ENLARGED STEPS FOR STAIR (2019)
Fri, Jul 19, 2019 at 1:06:03 PM | CREATE ENLARGED STEPS FOR STAIR (2019)
ledgewood33
i would like to create a stair with the lower 3 steps to be enlarged and my railing to go to the bottom floor. as apposed to creating a model-in-place family for those 3 steps where my railing doesnt recognize. i am attaching a pdf of this stair. in the pdf i have a description of what i want to do.
Thu, Jul 25, 2019 at 7:41:10 AM | CREATE ENLARGED STEPS FOR STAIR (2019)
tim123
4 Stars: 19 Votes
Go into edit mode for the stair and press 'Convert'.  The 'Edit sketch' button becomes available.  You can then use the boundary and Riser tools to edit the risers.
Fri, Jul 26, 2019 at 9:04:41 AM | CREATE ENLARGED STEPS FOR STAIR (2019)
ledgewood33
so i have been able to covert to edit but my problem is that i would like the lower 3 steps to be risers on all sides or at least 3 sides of the tread. as reflected in my screen shot that i attached to my original post. secondarily or as important is to get the railing to extend down to the bottom tread of those enlarged steps and not have the railing flatten out but keep the same angle as it does going down the stairs.
Fri, Jul 26, 2019 at 10:55:44 AM | CREATE ENLARGED STEPS FOR STAIR (2019)
You can edit those bottom treads to have risers on all sides but they must be riser lines, not stair stringer.
Sun, Jul 28, 2019 at 10:02:44 AM | CREATE ENLARGED STEPS FOR STAIR (2019)
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
You can also add a railing segment and adjust its slope and height correction - see pictures.
two steps from hell
Fri, Feb 10, 2012 at 2:29:38 PM
Stair Nosing on Enlarged Plan View
Tue, Jan 17, 2012 at 4:32:38 PM
How can I create a split stair without multiple and separate stair components?
Tue, Jan 5, 2016 at 5:32:53 AM
Issues with underside of stair
Tue, Mar 15, 2011 at 3:27:07 PM
stair plan
Wed, Oct 26, 2011 at 12:31:01 PM
Page generation time: 0.6720
