Forums >> Revit Building >> Technical Support >> Window elevations
Wed, Jul 17, 2019 at 8:26:36 AM | Window elevations
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
i have a long run of storefront that is curved, but not a true curve. the window panels are actually placed at shallow angles so small that they appear to be a curved unit. my question is i need to make a window elevation and dim and note but the elevation shows the storefront as it would look if you see it. which is fine. but how can i do the elevation to show the real size of the windows, ie "flatten it" so to speak, so they can be correctly sized? any ideas or suggestions would be great. i know i cant tbe the first one to come accross this matter.
thanks for any help
Wed, Jul 17, 2019 at 9:53:44 AM | Window elevations
Whenever I had this situation, on my window sheet, I included a plan view that only showed the storefront.  Then I used dimensions that where center to center of the mullion glass intersection.  Typicall I had an arc centerline at that point and I used a chord dimension.
Wed, Jul 17, 2019 at 11:16:14 AM | Window elevations
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
thanks, that is what is was leaning towards. just wanted to see if i was not alone.  thanks again
What are people using window elevations?
Thu, Jan 31, 2008 at 9:44:56 AM
how to add elevations to door & window schedules
Tue, Oct 30, 2007 at 11:59:24 AM
Window Elevations
Fri, May 18, 2007 at 5:18:02 PM
To Window Tag or not to Window Tag...?
Thu, May 21, 2009 at 12:33:24 PM
window sills
Sun, Jun 18, 2006 at 5:16:17 PM
Page generation time: 1.1269
