Forums >> Revit Structure >> Tips & Tricks >> Joining With Material Blend
Sat, Jul 6, 2019 at 8:28:42 PM | Joining With Material Blend
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
If you join elements (a wall and a column for example) the line btween the elements will dissapear if they are the exact same material. If they aren't the same 'material' they will join but the line between them will stay.
So if you leave them joined and change them to the same material the often the line will NOT dissapear. You have to make them the same material, UNJOIN them then JOIN them again for the magic to happen.
Your're Welcome !
Tue, Jul 16, 2019 at 12:02:22 AM | Joining With Material Blend
TravisSolomon
Yes, this is exactly we could do for joining the line.
Aligning surface pattern on double-curved ceiling (in-place swept blend)
Mon, Jun 22, 2009 at 3:29:10 PM
Roof Joining Issue
Mon, Jan 21, 2013 at 7:54:18 PM
12
Roof Joining
Mon, Jan 21, 2013 at 7:47:21 PM
Joining 2 objects with "Join Geometry" Tool
Fri, Sep 5, 2008 at 4:10:05 AM
wall solid blend
Tue, Aug 18, 2009 at 3:56:25 PM
Page generation time: 0.1943
