Forums >> Revit Structure >> Technical Support >> Gusset Plate to column base plate
Mon, Jun 3, 2019 at 9:57:11 AM | Gusset Plate to column base plate
otherguy
I am very new to Revit and was just trying to input a brace connection to a column base plate using the Gusset plate to column base plate connection.  It's just a W-shape, HSS brace.
I get the error message I have attached, just figure it's something simple I am missing, but I have watched videos and read lots of other post but can't find anything on this yet.
Mon, Jun 3, 2019 at 2:48:23 PM | Gusset Plate to column base plate
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
My guess is you need to switch the pimary / 2nd / 3rd connection elments. Click the connection itself in 3d and note the blue dots and connection order 1, 2, 3, etc. The small blue dot toggles the connection order.
Column base plate tag units display.
Mon, Nov 17, 2014 at 2:24:40 PM
base plate visibility problem
Thu, Dec 1, 2011 at 12:34:33 PM
Attaching a footing to a column with a base plate nested into the footing family
Thu, Jul 11, 2019 at 12:23:42 PM
Column Base Plate Nested Family - GCS Visibility
Sat, Feb 21, 2009 at 9:17:59 AM
Revit 2010 Extensions - Column Base Plate
Thu, Oct 7, 2010 at 1:44:47 PM
Page generation time: 0.5239
