Forums >> General Discussion >> Revit Project Management >> BIM 360 Revit 2019 data exchange compromise
Fri, May 24, 2019 at 10:32:06 AM | BIM 360 Revit 2019 data exchange compromise
HermanMunster
????? Has anyone else recieved this message from AutoDesk?
Hello—
You’re receiving this email because our records show you have a version of Revit software that may be vulnerable to data exchange compromise.
To ensure your security and connectivity, Autodesk Identity Services is providing patches and updates on the Autodesk Knowledge Network to resolve this issue.
If you are currently using the Revit Cloud Worksharing service (which is included in your subscription to BIM 360 Design and accessible via Revit 2015 and later versions), this update will impact you.
    • For all Revit versions on maintenance or subscription, you must update to the latest point release to continue to use Revit Cloud Worksharing.
    • You must also apply a Personal Accelerator (PAC) security fix once for any version of Revit.
    • Use Revit Cloud Worksharing with Revit 2015 or 2016? You must also apply the latest Autodesk Licensing Manager Hotfixes listed in the Autodesk Knowledge Network article above.
We urge you to make this update to any machines using the Revit Cloud Worksharing service before June 15, 2019, so you don’t lose access to the service. If you miss that deadline, you can apply these changes after June 15 to restore access. Meanwhile, your data will continue to be stored in BIM 360.
At Autodesk, we are fully committed to your security and success and appreciate your attention to this matter.
Sincerely,
Autodesk Customer Service
Can't Remove File from BIM 360
Wed, Apr 10, 2019 at 8:59:16 AM
BIM 360 Link Issues
Wed, Sep 12, 2018 at 12:10:50 PM
Sharing Revit Models and content - BIM 360, etc
Fri, Jan 11, 2019 at 4:17:08 PM
BIM 360 & REVIT IPD
Fri, Feb 17, 2017 at 1:29:08 PM
RISA/Revit Link
Wed, Sep 10, 2008 at 2:17:37 PM
Page generation time: 1.7853
