Forums >> Revit Building >> Technical Support >> Foundation Lines and Color
Tue, May 21, 2019 at 2:00:56 PM | Foundation Lines and Color
CDWdavid
5 Stars: 5 Votes
Revit 2018.2 and 2019
Hope that someone can help me to understand this. Which bothered me a lot.
The top of foundation is -5’-0”.
I changed the Structural Foundations to Red with hidden line, see Picture 1.
If I setup the bottom of the Primary Range at -6’-0”, then the lines are shown red hidden lines as I wanted. See Picture 2.
If I setup the bottom of the Primary Range at -4’-0”, then the lines are shown black solid lines. See Picture 3.
Mon, Jun 3, 2019 at 3:00:31 PM | Foundation Lines and Color
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
-4'-0" is above the top of the foundation wall. Therefore it uses the linestyle <beyond> which is probaby solid and black. To test it change your linestyle <beyond> to be different (blue dashed) and see what is does. The <beyond> linestyle is global however and not exclusive to walls. It impacts any element that gets captured 'beyond' the view range.
Changing Linetypes in Foundation Plan
Thu, Mar 18, 2010 at 7:18:01 AM
dashed line for foundation footings?
Thu, Feb 9, 2006 at 4:04:06 PM
Foundation lines showing up hidden
Thu, Jul 12, 2012 at 4:55:00 PM
Lines color legend
Tue, Dec 24, 2013 at 9:36:24 AM
Foundation Wall Issue
Tue, Mar 23, 2010 at 4:59:46 PM
Page generation time: 0.3637
