15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Columns missing
2 Posts No Rating |
There are 4x4 columns at the outside corners of this porch but they are not showing.
The column at the rear has a space cut out of it.
Can anyone enlighten me why this is happening?
Thanks,
Gary
Probably just tured off in VG.
2 Posts No Rating |
Thanks, but , so far, all I have found is that if the column in in a wall, then the program will not let it show, even if the wall is hidden,
The only way I have found to make them show, so far, is to delete the wall.
Does anyone have any thoughts on that?
Thanks!
Use a structural column. The Architectural columns blend with the walls.
You can open the column in the family editor and change it's category to Structural.
2 Posts No Rating |
Thank you!
I think I set it to strucural but no change.
Unable to print all columns |
Fri, Aug 1, 2008 at 7:29:11 AM
hidden columns |
Fri, Mar 26, 2010 at 10:53:36 AM
Showing columns from the floor above |
Mon, Jun 9, 2008 at 1:49:48 PM
Keeping Columns in Place |
Thu, Jun 30, 2005 at 7:56:45 AM
Attaching columns to roofs? |
Wed, Jan 11, 2006 at 5:59:55 PM
