12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Model in place sweep error
Good afternoon,
I am currently trying to sweep a kerb on a road I have made on a topography. I am recieving an error issue whenever I try to close the sweep. It works fine, providing I don't close it. Is there any way to fix this?
Thanks
You have a couple of tight corners in this sweep. Profiles will not work if they can't turn this tight corner. Examine your profile family and experiment with where the profile is in relation to the y axis. Experiment and you will learn what is going wrong.
Also check that your path is on the inside of the curve - this allows for tighter radii.
Profile uploading for model in-place component sweep |
Sun, Oct 21, 2012 at 6:28:14 AM
Sweep Profiles in Version 9 |
Thu, Aug 3, 2006 at 2:14:05 AM
Void Form in a Wall Sweep |
Wed, Dec 1, 2010 at 6:58:00 AM
WALL SWEEP THAT I NEED A REVEL IN |
Thu, Apr 19, 2018 at 3:12:41 PM
In place sweep- change of level? |
Tue, Apr 8, 2014 at 7:33:57 AM
