12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> window schedule - skylights
my skylights and roof hatches are scheduling and i dont want them to be. is there a toggle somewhere that i can make them not schedule?
worse comes to worse, i can put a blank filled region over them, as they are the last two rows on my schedule, but it would be easier if i could just omit them from the schedule.
thanks,
GD
i am still an idiot...is there a way to fix this that i am missing?
Post edited on 2006-06-06 18:50:33
Go into your filters on your schedule and set the numbers to only show up to last true window then the rooflights will not appear on the schedule
any hints as to forethought that might go into filtering. Seems like a powerful asset, do you just create filters as you go or are there some "standard filters" that I guy could tap into??
a little trick i stumbled on -
for items you do not want tagged, give them a mark, eg z1.1, instead of w1.1, and filter your schedule to only show 'w'. i sometimes use window/door openings but no actual joinery, and call them z something. same thing could work on skylights.
Thank you for the suggestions.
LOOKING THROUGH THE WINDOW, SCHEDULE |
Sun, Dec 19, 2004 at 7:03:39 PM
Skylights not associating with room |
Sat, Dec 11, 2010 at 1:18:26 AM
Window's dimension don't show up in the window schedule |
Fri, Aug 17, 2012 at 1:34:43 PM
Adding skylights and slopes to a roof |
Thu, Jul 12, 2012 at 8:33:07 AM
door in window schedule |
Thu, Apr 29, 2010 at 7:47:41 AM
