Forums >> Revit Building >> Technical Support >> REVIT Structure and Architecture for wood framed buildings
Mon, Mar 25, 2019 at 5:08:43 PM | REVIT Structure and Architecture for wood framed buildings
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Ok Im interested in any input on this. Fairly large wood framed multi residential 4 story building.
In house REVIT Architecture and Structure using liked REVIT models.
The Architectural modeler insists on including elements other than the 6" wood stud layer in the Core for cleanup purposes both in plan and in elevation.
SO . . . . in the strucutural model when we copy monitor the arch'l walls (load bearing only) to our structural 6" stud walls there is NO WAY to line up our 6" walls (all core) automatically with the arch'l composite walls because we have different core thickness. SO . . . we have to copy monitor the walls, then manually 'align' our structural 6" walls to the arch'l walls corect 6" layer edge and then 'accept the difference' to the coordination review for each wall (many many many walls).
OR do we insists the arch'l people make their wall cores only the 6" so our structural copy monitored walls automnatically line up and then address their arch'lwall cleanup problem as a result of that ?
What a dogs breakfast eh ! Concrete buildings do no have this problem. Just wood framed buildings.
Any input or thoughts on how others might be doing this wood framed arch'l / struct'l modeling ??
Thx
DG
Thu, Apr 18, 2019 at 2:16:17 AM | REVIT Structure and Architecture for wood framed buildings
tim123
4 Stars: 19 Votes
Would it not be an option to include an additional layer (such as thermal) in your core to compensate for the Arch stuff?  The core thickness and the total thickness should ideally be the same in both models.  The workflow that you describe sounds horrible.
Thu, Apr 18, 2019 at 2:38:02 PM | REVIT Structure and Architecture for wood framed buildings
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Engineers most definitely do NOT want to include thermal layers in their walls. They just want the structuraal aspect (core/ studs) but unless both architectural and structural walls have the exact same core thickness copy/monitor will not work. That's the crux of the entire problem. Unless someone else has a workaround ?
wood framed walls
Sat, Sep 16, 2006 at 5:04:06 PM
recommended way of modeling wood-framed roof?
Mon, Nov 5, 2012 at 3:34:01 PM
Help required with portal frame buildings
Mon, May 9, 2005 at 1:27:29 AM
Wall Structure
Mon, May 11, 2009 at 2:10:04 PM
Altering Revit Structure Wood Beam Families
Mon, May 14, 2012 at 2:10:01 PM
Page generation time: 1.4663
