Forums >> Revit Systems >> Technical Support >> "Xref" in Revit
Sat, Mar 23, 2019 at 5:43:06 PM | "Xref" in Revit
jacopojacopo
Hi there,
I am enquiring about "xref" concept in Revit.
I would like to know if it is possible to adopt such concept in Revit, I am pretty sute is possible as the xref are called families in Revit right?
I work on big industrial projects consisting of 10+ factory units development, the way we work in Autocad is by trying  to make it as typical as possible, creating one typical unit plan and then xref it along the all site so we only work on one plan.
Can you do the same in Revit?
I was thinking that you could create the "typical" plans as families and then import them into the main file, but as I am not too confident with the software yet I am looking for some advice.
Is there someone which could point me in the right direction?
Thanks J
Sun, Mar 24, 2019 at 7:52:43 AM | "Xref" in Revit
Revit does not use xrefs, you can link in consultant models and control what elements of their models show in your file.  When they update their model, you can reload the link, inspect their changes and accept or reject them.  Typically, the architect produces the base building file which the MEP and structural consultants link into their file.  They then, just like the architect, can control how this base model is shown in their project.
Revit families are similar to Autocad blocks but families are far more powerful.
file getting too big, is there "xref" or something similar?
Fri, Apr 18, 2008 at 12:19:41 AM
"XREF" Families or other possibilities?
Fri, Apr 4, 2014 at 1:47:41 AM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
When I copy an "existing" element it reverts back to "new construction."
Mon, Jun 16, 2008 at 2:38:24 PM
tagging by "family name" and "family type"
Mon, Jun 1, 2009 at 8:54:54 PM
Page generation time: 2.4748
