16 Users Online (14 Members):
Forums >> General Discussion >> Revit Project Management >> converting revit sheet to image
I converted my revit sheets to image with the pixel size corresponding to the particular sheet size. The resulting image has a black outline along the edges of the image and while printing it comes as a border with some distance from the edges of the sheet. So the actual sheet is getting scaled down and printing within a border that i didnt specify.
The same thing happens when converting to pdf also. Any ideas on how to solve?
Edited on: Sat, Mar 23, 2019 at 7:01:26 AM
Edited on: Sat, Mar 23, 2019 at 7:02:20 AM
Edited on: Sat, Mar 23, 2019 at 7:02:45 AM
Edited on: Sat, Mar 23, 2019 at 7:03:27 AM
Why would you ever convert a sheet to an image? Print directly to PDF if you need it to be portable.
Inserted Image prints upside down |
Sun, Nov 13, 2016 at 9:42:45 PM
Converting DWG materials to Revit Materials |
Thu, Sep 13, 2012 at 3:50:29 AM
printing a sheet with a image |
Fri, Feb 3, 2006 at 6:06:35 PM
I put an image file behind an elevation but it doesn't print properly... |
Sat, Mar 12, 2005 at 8:00:35 AM
Links to each sheet in sheet index |
Sun, Aug 21, 2016 at 11:06:31 AM
