Forums >> Revit Structure >> Technical Support >> Can't select beams nor columns
Sun, Mar 10, 2019 at 9:45:13 PM | Can't select beams nor columns
athens1
so i go to modify > geometry > beam columns joins and then the screens turns white in 3D and i cant finish the process. and in floor plans i cant see the beams! and same thing, im not allowed to do the operation of joining beams to columns. idk what the problem is. I'll attach a capture of what the white screen looks like in 3D
Sun, Mar 10, 2019 at 10:12:36 PM | Can't select beams nor columns
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Probably it doesn’t work because the beams are not joined. Use Trim/Extend tool first and then Beam/Column join tool as needed.
Columns/Beams won't cut wall & wall beyond is visible
Thu, Jun 21, 2012 at 9:19:31 AM
Beams won't intersect or close-up to Structural Columns. Solution ?
Tue, Oct 18, 2016 at 2:01:11 PM
BEAMS JOINING COLUMNS problem
Tue, Jun 30, 2015 at 7:41:51 AM
Concrete Columns and Beams cuts through wall...
Mon, Feb 4, 2013 at 8:10:15 AM
Walls and Structural Beams/Columns and Finishes
Tue, Jul 19, 2016 at 3:46:11 PM
12
Page generation time: 0.4325
