23 Users Online (21 Members):
Forums >> Revit Structure >> Technical Support >> Floor material angle problem
0 Posts No Rating |
Hi everyone, I have 2 big problems.
1) When I use same material in different rooms for floor covering, change in the direction of floor covering in one room effects the other rooms, eventhough they are created seperately and named differently for each room.( 1st and 2nd picture)
2) The building I'm working on has an ellipse form, so the corridor in the center must have an angled joint direction varying from start to finish. How will I change it? In autocad I could do it with array command but in Revit I couldn't figure it out (3rd picture)
Read you help on the different types of hatch patterns - drafting vs model.
0 Posts No Rating |
WWHub , couldn't understand what you mean...
My answer was for your question #1. Your floor material should be defined using a model pattern. That can be rotated independetly.
Question 2 - You can't do this with normal fill patterns.
material image at different angle |
Thu, Oct 23, 2014 at 1:19:46 PM
Floor Help |
Sat, Oct 23, 2010 at 9:07:02 PM
3D in place sweep problem, changes angle |
Mon, Jan 28, 2008 at 12:56:37 PM
Can Floor Slab Edge Material be different? |
Thu, Dec 1, 2011 at 3:44:57 PM
Site material and floor material |
Mon, Feb 18, 2008 at 1:31:04 PM
