Forums >> Revit Building >> Technical Support >> Convert Project Parameters to Shared
Mon, Feb 18, 2019 at 11:45:11 AM | Convert Project Parameters to Shared
SteveB
3.5 Stars: 5 Votes
Many parameters come into a project from 3rd parties with project, not shared, parameters.  Is there any way to convert selected project parameters to shared, so they can be displayed as labels in a tag?    I am pretty sure there is no way to make tags that display project parameters, but that would be a work around, if possible, as well.
Mon, Feb 18, 2019 at 6:23:29 PM | Convert Project Parameters to Shared
Project parameters can be shared parameters so check first to see if they are.  If they are, you can export to your shared parameter file.
Shared or Project Parameters?
Tue, Jan 19, 2010 at 7:01:11 PM
Project Shared Parameters or Shared Parameters in Families
Fri, Feb 21, 2014 at 10:22:42 AM
Shared Parameters
Thu, Feb 9, 2006 at 1:41:58 PM
Automatic shared parameters
Wed, Mar 9, 2011 at 8:23:17 AM
Using alle the project parameters in label (not shared parameters!
Fri, Nov 30, 2012 at 7:23:04 AM
Page generation time: 1.8817
