Forums >> Revit Structure >> Technical Support >> Screened revision cloud lines
Mon, Jan 28, 2019 at 11:13:40 AM | Screened revision cloud lines
Lenhoksin
Does anyone know if you can screen the revision cloud lines to print screened? When you cloud items especialy when your just changing a number we don't want the cloud to cover other items. And halftone just changes it on the screen not when printed.
Thanks in advance.
Mon, Jan 28, 2019 at 1:10:40 PM | Screened revision cloud lines
Learn  to use your HELP - it really answers a lot of questions.  Searching halftone settings, you find this:
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-3B363D33-70F7-491C-9ED0-9D27977E635F
Tue, Jan 29, 2019 at 6:38:22 AM | Screened revision cloud lines
Lenhoksin
Thanks for your responce WWHub. I do use the HELP file. I need to re word my question. I want to make the Revision Clouds Transparent not halftone when we print. I have a feeling that I can't in Revit.
Thanks again
Tue, Jan 29, 2019 at 7:00:47 AM | Screened revision cloud lines
I wish you had read the link I posted.  If you had, you might understand how to set up your halftone so that prints like you want.  The issue is your settings.
Tue, Jan 29, 2019 at 10:49:17 AM | Screened revision cloud lines
Lenhoksin
Perhaps I am still not explaining clearly what I want.  I am able to make the clouds half tone, but when the clouds overlap with other objects, the clouds block the information underneath such as text.  Please see the attached pdf file.  I would like to be able to put the cloud behind other objects or have the cloud print transparent so you can see both objects - the cloud and text.
Tue, Jan 29, 2019 at 4:53:05 PM | Screened revision cloud lines
You did complain that halftone did not print and that was what I responded to.
Clouds are always on top so you have to draw them so they do not cover up important information.
Fri, May 3, 2019 at 9:48:16 AM | Screened revision cloud lines
rbrown
Use a print driver that allows line merge.  For Bluebeam under "General Settings" check the "Line Merge" checkbox, select "Advanced", select Blend Mode "Darken", select Opacity "100%".  See results in attached image.
Fri, May 3, 2019 at 1:09:18 PM | Screened revision cloud lines
We never found a reason to use Bluebeam but this looks like it may be useful.  Maybe thngs have changed since Bluebeam first came out.
Revision clouds
Thu, Apr 24, 2008 at 3:12:44 PM
Revision cloud closes revit
Fri, Sep 28, 2012 at 10:47:52 AM
Hiding a Revision in the Revision Schedule
Thu, Nov 21, 2013 at 3:04:51 PM
Revision Cloud graphics
Mon, Aug 24, 2020 at 7:00:24 AM
Revision cloud parameters
Mon, Feb 25, 2008 at 7:53:53 PM
Page generation time: 0.2989
