Forums >> Revit Systems >> Technical Support >> Looking for a GRP elbow, or thoughts on how to create one
Sun, Jan 27, 2019 at 10:42:40 PM | Looking for a GRP elbow, or thoughts on how to create one
kelasa
I'm an BIM designer. I was approched by our Civil and Tunneling department and they are asking if I could create them a Glass Reinforced Plastic Elbow fitting. I haven't created many families from scratch in Revit.
Has anyone seen a 3D CAD model, or Revit family of this type of elbow?
Does anyone have any reference to a tutorial site that could help me make this?
Thank you for your time.
Mon, Jan 28, 2019 at 1:37:36 PM | Looking for a GRP elbow, or thoughts on how to create one
I don't do civil work so I'm not sure if my question is applicable.  Do you want an elbo that will automatically connect to Revit piping or just a model family?
If this is just a standard family, it would be relatively easy to model.  Just segmented extrusions.
Mon, Jan 28, 2019 at 3:13:13 PM | Looking for a GRP elbow, or thoughts on how to create one
kelasa
Thank you. Yes, it would be best if it is able to connect. Thank you much. I will research modeling an elbow with segemented extrusions!
Revit Dimension Straight Leader Line with Controllable Node at Elbow
Thu, Jul 12, 2018 at 12:32:47 PM
How can I do when every size elbow parameter still use 100mm elbow parameter
Fri, Dec 3, 2010 at 2:00:26 AM
Cable Tray Elbow
Thu, Jul 3, 2014 at 8:23:38 AM
How to retrieve start point and end point of Elbow
Wed, Jul 6, 2011 at 3:47:48 AM
Duct Elbow Angles
Thu, May 22, 2014 at 1:14:44 PM
Page generation time: 1.2720
