Forums >> General Discussion >> Revit Project Management >> All views are gone
Wed, Jan 23, 2019 at 11:31:51 AM | All views are gone
dannost
Help!
I opened a revit file I was working on yesterday and ALL views are gone.  Schedules and legends are still there.
Sheets are still there, although empty since all the views are missing.
The model is still intact.
Anyone have this happen?
Wed, Jan 23, 2019 at 1:09:23 PM | All views are gone
If this is true, it is not a program issue, it would be user error.  Are you the only one working on it then look at your process.  BTW, Revit always has a backup - not to yhe last you have done but look at restoring it.
Wed, Jan 23, 2019 at 5:22:05 PM | All views are gone
dannost
I can't imagine what error could delete every view.  Is there a command that would wipe all out at once?
I have it set to back up 2 copies and tried both - same issue.
Luckily I went back to a backup on an external drive from a couple days prior that was OK.
HELP! ALL of my plan views vanished!!!! I've tried creating new views
Wed, May 9, 2018 at 3:18:43 PM
Identical Views act differently
Tue, Aug 28, 2012 at 3:04:30 PM
Create Work views
Thu, Feb 18, 2010 at 3:38:08 PM
any work around for this? transparent glass in shaded elevation views, revit 201
Mon, Jan 28, 2013 at 11:19:53 PM
Views deleted!!
Mon, Apr 11, 2011 at 2:44:15 PM
Page generation time: 0.5017
